cryptography
Hi ,
 I want to get back the original signal using cryptography, Can any one explain me about this and what blocks are needed for that.
Where can i found about cryptography. I need few examples of cryptograhy algorithms
(3,928 Views)
I don't think it is feasible to unencrypt your signal unless you know the algorithm and key that was used.  That is the whole point of encryption.  Smiley Wink
Here's a good example of the Blowfish algorithm, though:  http://zone.ni.com/devzone/cda/epd/p/id/3473
http://www.medicollector.com
(3,857 Views)
Just take a look at wikipedia, e.g. here is the Blowfish.
A LabVIEW code can be downloaded as stated above.
For the implementation of other algorithms, check one of the many Open Source tools for cryptography (gnupgp, truecrypt). I guess that some of these tools take reusable libraries for this, so you could call them from LV as dll's.
Felix
(3,848 Views)
Previously asked as "inverse of hash function".
(3,836 Views)
