csv,2D
@nananass wrote:
Thank you very much.
I have two more questions. When using a sampling clock, is it possible to achieve the same functionality of running with the same 0.1-second interval when creating AI channels?
Also, if I want to save the AI data every few seconds, what should I do?
Yes, but you can't set the sample clock as low as 10Hz. You'll need to set it to 1kHz and e.g. grab 100 samples at a time and take the average. That'd actually give a better timing than the software wait.
For saving, i'd build up an array and once it reaches a certain size, e.g. 100 if you want to save every 10 seconds, save to file and empty the array.
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 31
(1,536 Views)
Thank you very much. Thanks to you, I was able to create it successfully. It's all thanks to you.
sheep
Message 12 of 31
(1,516 Views)
I apologize for the basic question.
I am using this timer as a sub-timer to measure seconds, but when I try to use it as the main timer, it works within the sub-timer but the values are not reflected in the main timer even though it is running internally. I want to measure in 0.1-second increments, so I would appreciate it if you could tell me how to solve this or suggest an alternative method.
sheep
Message 13 of 31
(1,522 Views)
Hi nana,
I guess this question is still related to your other question(s), so I merged the threads.
Why don't you set the DAQmx task to use a 10 Hz sampleclock? (Or 1kHz sampleclock with a decimation factor of 100?)
Message 14 of 31
(1,509 Views)
The sample clock is running, but it is not outputting until the specified time. It keeps outputting one after another without much regard for the timing. I want to fix this cause. However, I can't solve it on my own, so I'd appreciate any hints you could give me.
sheep
Message 15 of 31
(1,504 Views)
Hi nana,
Well, I could help much more once you downconvert your VIs to an older LabVIEW version. (File->Save for previous)
See my signature line: I prefer LV2019…
Message 16 of 31
(1,515 Views)
Excuse me.
I have only downloaded the 2023 and 2025 ones, and I have been instructed by the upper authorities to use this version. Is it possible to write the Japanese part in English and send it as an image?
sheep
Message 17 of 31
(1,511 Views)
Hi nana,
@nananass wrote:
Excuse me.
Each LabVIEW version provides the File->Save for previous item in the menu.
What's your problem to downconvert your VI(s) and attach them here? You still can work in your recent LabVIEW version!
Message 18 of 31
(1,508 Views)
HI,GerdW
I see! I’ve attached the folder here. I think it’s saved in the old version, but I’d appreciate it if you could check.
sheep
Message 19 of 31
(1,464 Views)
Hi nana,
Only the project file itself is converted for LV2019, but all the VIs inside the ZIP still are saved with LV2025!
You need to save the whole project for LV2019…
Message 20 of 31
(1,456 Views)
