csv file as input?
I have and csv file with voltages. Now I would like to read this CSV file with an LabView programme and send the voltages to an analog output of a DAQ Card. (Each microsecond one Voltage value)
Is that possible?
regards
doctorbluex
(2,805 Views)
Read your file using "read from Spreadheed file" and wire a comma as delimiter. (Transpose if needed).
You'll get an array that you can use for any purpose (display in a graph, send to AO, etc.). Just slice out the desired row or column. 😉
(2,792 Views)
