ctrl click to select multiple objects
is it possible to ctrl + click multiple objects on a block diagram to select them? I have tried and it doesn't work. Seems like that is some common functionality that is missing. I will put it in the idea exchange, but I wanted to see if there was a solution already that I'm missing. Thanks.
(4,600 Views)
Try Shift-click.
(4,598 Views)
You use Shift+Click to select multiple objects.
(4,597 Views)
god you guys are fast...thanks!
(4,590 Views)
