ctt & vit files
I created a vit file from an existing vi that used a ctl file for semaphore elements. After installing the vit template I noticed that the link to the original ctl file still exists.  I created a ctt file from the original ctl file and installed it into the directory where I installed the FSM.vit and FSMd.png files, but I am still linked to the original ctl file.  How do I create the link from the vit file to the ctl file?
(3,924 Views)
Why are you wanting to have your code linked to the ctt?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,916 Views)
My template uses this ctt template and I want it completely separate from the original ctl file that was used to create the original vit template, and any program that uses the vit to create a new vi will be using a different version of the ctl since it is used by the producer as an enumerated element.  This particular design adaptation of the produce-consumer template as I have used two times before, and each time the only major change that I  need to do is change most of the enumerated elements in the ctl which is used in many places in the vit file.  So if I create a new vi from the template I can then just edit the enumerated elements for the new project without changing the one an only copt of the ctl that was used in a previous project.  I need tight coupling within the project and no coupling between projects.
(3,895 Views)
hounddog,
Have you tried just removing the .ctl from the .vit and adding the .ctt in its place?  Are you using a typedef (strict or non) or just a control?
Jared Boothe
Staff Hardware Engineer
(3,868 Views)
I'm using strict type defs:  the .cit template will ultimately be used to create a .ctl of enumerated types both to run the messages from the producer to the consumer via the msg queue and as a state element in  a state machine in the consumer loop.  If I create a new project VI from the .vit template I'll end up with a VI that I can readily customize.  I also want to create a .ctl from the .cit template that is also independent of any other 'instance' of the .cit template so that various applications using this template are not tied together by a common .ctl file.
(3,787 Views)
Accepted by topic author hounddog
Hi hounddog,
I created a simple .vit using a strict typedef boolean .ctl to try and recreate what you had.  I then opened the .ctl in the template VI and saved the control as a .ctt to the same folder as the .vit and it appears to be linked correctly.  I did a Save as... and then substituted the copy for the original.  Is this any different than the method you are using?
(3,766 Views)
