cumsum
I want to generate a vector that is the cumulative sum of another vector without using a loop. My vector is more than 10^6 in length, and a loop takes forever. I use cumsum in matlab, but couldn't find anything analogous in labview.
Thank you!
Message 1 of 9
(7,334 Views)
Does your LabVIEW license make the matlab script node available and do you have Matlab on the computer you will be using? If so, you can use the matlab script node and type the cumsum function right into it.
Message 2 of 9
(7,330 Views)
yes, I thought about it, but I was hoping I can do the same easily without using Matlab functions. Otherwise I'll just write the whole program in Matlab.
thanks anyway!
Message 3 of 9
(7,326 Views)
Hang around a bit, someone might know better than I would.
Here is a link to what cumsum does.
Message 4 of 9
(7,322 Views)
MathScript also supports that function. Not sure if it's actually going to be faster than LabVIEW code. What does your LabVIEW code look like? Can you post the VI? You may have some inherent inefficiencies in your code.
Message 5 of 9
(7,318 Views)
Accepted by topic author abz_999
This works for a 1 d array of a million elements...you will have to mod it a bit for a 2d array but it hardly takes any time at all to execute. You must have some inefficiency in your code. If you need to do either columns or rows, I can mod it a bit for you, but you should try it on your own first using this example.
Message Edited by for(imstuck) on 05-14-2010 12:43 PM
Message 6 of 9
(7,308 Views)
Thanks so much, my mistake was to disable indexing in the loop (aghhh...).
thanks all for helping.
Message 7 of 9
(7,287 Views)
Should th SR be initialized?
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 8 of 9
(7,265 Views)
Doh, good catch. Yes.
Message 9 of 9
(7,255 Views)
