cursor in a graph
I have plotted a graph from a certain data that contains x-information and y-information (voltage vs. temperature). I would lika a cursor that gives me both the x-value and the y-value. i can't seem to get it to work. If I have a cursor that reads the x-data, it's doing that properly. But since it it redaing the data from the x-axis and not really from the data I can't compare it with the arry in, sice the value from the axis might not be exactly what I have in the data. So, can I somehow use a cursor that only read data that is actually in my data information?? Or, if I use the cursor like I do now, where I get the information from the axis, is it possible to get the value from the y-axis somehow. Since the graph plots the graph even where I don't have any data, it musy be possible to get the information from it.
Someone that can help me? Thank you!
(2,481 Views)
Hi
Lock the cursor to the plot and you will get the corresponding values.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,479 Views)
