cursor legend shows extra plot names
hi need help ,
wen i plot data to graph i can see there is extra plot names in the cursor legend .
wen i check the data, it passing it correctly. wat should i do?
i attach the picture wit this
plz help.
im using labview 8.0
Message Edited by jeyanthi on 06-22-2008 10:09 PM
(3,725 Views)
Hi jeyanthi,
can you upload a picture of your code please? If you use the "Array to Cluster" function, then make sure that you set the correct size there.
Mike
(3,709 Views)
hi i attached the code.
when the data is it pass  extra data..
so i use loop and pass the exact data to graph.
the graph data is correct but..
i dono y there is extra plot names i  cursor legend
(3,704 Views)
(3,700 Views)
Hi jeyanthi,
in the xy-graph options you can set the visible number of plots. It´s on the first tab page.
Mike
(3,690 Views)
