cursor moved by refresh of window or printout
in LV 8.2 I am using a XY-graph with two cursors. The cursors are fixed to the plot. The cursor position will be changed by the program. If the window will be refreshed by moving the window or making a printout, the cursors are jumping to the initial position (default value). So every time when the window is removed or an other window appears in front of the window, the cursor positions are changed. I am not able to make a print out with cursors on the positions I need.
I seems to be a bug of LV 8.2. Is the bug known? Is any bugfix available?
(2,499 Views)
Obviously your described behavior is not a knowing issue.
Could you please attach a small example VI, so I can try to verify the problem and can contact my college’s in the development department.
Kind regards
U. Möschel
AE NICER
(2,482 Views)
