curve fitting gives input, at the output
Hi everybody, i am having a problem at curve fitting function,
i take at output, what i give as input, where do i make mistake?
at example i give 4 values, if i enter 6 values it works, but i need to do it with 4 values.
any ideas?
thanks
Message 1 of 19
(3,838 Views)
take a look a the help topic about the non-linear fitting VI :
Apparently what you did was creating a constant on the f(x,a) termanial, this then causes an error because the VI is expecting you to create a VI from a template. You either have to create that VI or use a different fitting method.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 19
(3,832 Views)
Hi, thanks for ur answer
I did it with nonlinear curve fitting function, but there should be some mistakes, still doesnt working?
Message 3 of 19
(3,822 Views)
Bye the way, i dont know how to decide initial parameters, can anybody help me with that?
thanks
Message 4 of 19
(3,810 Views)
What's wrong? it works fine for me... what error are you getting?
Of course you need to input an array containing 3 values in "initial parameters" for the initial values of a1, a2 and a3.
Hope this helps
Epictetus
Antoine Chalons
Message 5 of 19
(3,809 Views)
thanks, i didnt put 3 values for it, i will try it like that.
and how can i determine, which values should i write as initial values?
Message 6 of 19
(3,786 Views)
i entered 3 value as u said, now i dont get any error, but output is same as input. function doesnt make any curve.
if u got curve, can u share ur initial parameters with me
Message 7 of 19
(3,778 Views)
Please include your data.  What values are you using for Array and Initial Parameters?  With only 4 data points you may have a system which either matches perfectly to a the curve or which cannot be matched by a second order curve.
For example an input of 0,3,3,0 with initial = 2,2,2 produces -6.8E-17, 3, 3, 1.7E-15 which plots identically to the input.
Lynn
Message 8 of 19
(3,765 Views)
Your function is a simple quadratic polynomial, so you should use the general polynomial fit function instead. Don't overcomplicate things 😄
Message 9 of 19
(3,755 Views)
sorry, i thought datas will be visible if i upload program.
i used as input
0.005
-0.05
-0.05
-0.005
as initial values, i have no idea what should i write, which value:/.
i need to do it with 4 data,
thank you
Message 10 of 19
(3,753 Views)
