curve fitting of 2d edge detection data
Hi all,
I have attached intensity graph which is obtained from edge detection function. Its a 2d array of numeric data. I wanted to do a curve fit for this data. Can anybody help me.
KM
(3,238 Views)
First thing you have to have a clue about is the curve form. Is it a cylindric/circle form or a sine or else. Then you choose the proper fiting function in Mathematics > Fitting.
I assume it is a cylindrical form, so I would go with the "Nonlinear curve fit" and implement a formula string for z=z(x,y).
(3,212 Views)
hey thanks for your reply, plz find the intensity graph data attached to the post. i am supposed to do fitting for this. I guess parabolic fitting will do for this. How should i go about it?
KM
(3,179 Views)
I wonder that you have nobody [the designer] to ask, what was to original form to create.
Can you do something using my suggestion earlier?
(3,171 Views)
Don't you first get coordinates (Y and X) of white points, and then do a curve fit?
Remove points on top and bottom first.
(3,155 Views)
