curve fitting
Hi everyone,
I have a sample VI attached to the mail. In this VI, I'm trying to fit a curve to 2D array that is obtained as a result of 14 while loops. The x-axis of the graph should be the 1. column of the 2D array, and the y-axis of the graph should be the 2. column of the 2D array. However, the values of x-axis are the number of while loops between 0 and 13. But, the y-axis is the 1. column values. So cloud you please help me? Basically, after 14 while loop iterations, there is a 2D array, and I want to fit a curve for this 2D array, in which the 1. column is x-axis, and the 2. column is y-axis. Helppp please!!!!!
(2,963 Views)
Let's keep this all in one thread. No need to clutter the forum.
(2,952 Views)
