custom excel report
When dumping data from labview into a custom excel template using the report generator in labview 7.1, I get a column of unwanted data.  It appears to index all the data I am trying to get into my template.  So now my named ranges are off by one column: eg name A2:A100 for energy does not contain the energy data, instead is contains the numbers 1-99, and B2:B100 contain the energy data.  Is there any way to get rid of this indexing?
(2,755 Views)
Delete the Column before you wanted Data column. sometimes you can have a array that looks blank but is not.
(2,752 Views)
