custom listbox control
Im using a cluster to store and display some data, its a boolean and 2 strings. I have customized the look of the indicator of one of this cluster elements. (see 'Cluster' in the attached screenshot)
But I would like to display more then 1 item and be able to scroll if its more items then screensize. But how can I put these cluster items in a listbox and customize the look of the listbox to match what Im looking for?
I have done this with an array and it looks good but I want a scrool bar and not the 'index display' to control what items should be displayd in the array. (see 'Cluster Array' in the attached screenshot)
(4,289 Views)
Hi Tudor,
you can use a scrollbar control to scroll the array. Instead of using your data in an array of cluster you can use a tree control with your own icons.
Mike
(4,283 Views)
where can I find the scrollbar controll? Im using lw 7.1
(4,275 Views)
Hi Tudor,
i can't check it now, in LV85 they are in the numeric palette.
Mike
(4,269 Views)
I only have slide controlls in my numeric palette. I found it on labview 8.2 but not in lw 7.1 that im using for this project. Is it possible to save the scrollbar controll to a previous version? I could save it as 8.0 but not any lower becuase I dont have lw 8.0.
(4,260 Views)
Hi Tudor
Sorry to say but if you have a look at this KB you can see that you need LV8.0 to save a VI to a LV7.1 version. Also, functionality that has been added in a later version while most likely not work in a previous version. Like Mike suggested I think a tree control would be a good way to go
Best Regards
David
NISW
Message Edited by DavidEk on 07-13-2009 03:08 AM
(4,147 Views)
