customising time stamp control display on front panel
In the window which appears when I click on the calender icon of the time stamp control panel, I would like to customise the display format of time stamp string to show only current date(and no time) and i would like to hide the 'set time to now'  button in the time stamp control. attached is the current pop up view of the control on my front panel. How do I do this?
Thanks.
(2,869 Views)
If you want only date and no time in front panel then change in block diagram. This set time to now then will pose no problem.
Here
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,850 Views)
