customize default front panel settings
How do I set a default color for the front panel?
(2,720 Views)
From the Tools menu, select options and then colors. Unselect the "Use Default Colors" box and you can make the default front panel any color you want. One thing that I always do is set the coercion dot color to red so that it is easier for me to see when data conversion is taking place.
(2,720 Views)
