customize for loop to run from x value to y value
How can you customize a for loop to run from a specified i-value.
Basically how can I do this c code in Labview:
for(i=2; i<10; i++)
(3,002 Views)
You can do it using a while loop conditional on i<10, or have a case inside a for loop that is conditional on the i<10. For loops, in LabVIEW, execute for a specified number of iterations and don't actually have a means to terminate early, so the only way to simulate this it to have them loop more times than needed and have a conditional case statement inside that only executes during the appropriate iterations.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,988 Views)
Guy04,
you cannot influence the iterator of any loops in LabVIEW. So there is (sadly) no way to initialize the iterator to a value != 0.
Nevertheless, you can "emulate" this by doing what i did in the screenshot. Just remember that "N" has to be the difference between end- and startvalue of your iterator (in your example 10 - 2 = 8 ).
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(2,975 Views)
Hi Guy,
you can also emulate this for loop with a while loop and a shift register:
Message Edited by GerdW on 01-05-2007 10:20 AM
(2,973 Views)
