customized waveform
I need to create a waveform chart as shown in the attachment with channel no label on the peaks just to indicate which channel the peak occured. Please need some help. Thanks
(3,886 Views)
Is it possible to use any property to implement the label.
(3,867 Views)
If the number of channel, frequency etc. are fixed, then you get the position of peaks (with some trail and error method) on graph and can try to move some string indicators position based on values on graph using property node. 🙂
Sanad MM
(3,847 Views)
Check out this example called Adding Comments to Specific Points on a Graph (http://zone.ni.com/devzone/cda/epd/p/id/62). I think that will get you started. There is no simple way to do this but it is possible. Good luck!
(3,832 Views)
I am using chart instead graph. Is it still possible to do that. It doesn't have a property cursor.
(3,821 Views)
Cursor legends and cursors are only available on graphs.
(3,803 Views)
