customizing Array
Hey all,
I am currently working on a project to make a pong game, but I need the spaces in my LED array to not be there I have tried to costomize it but so far nothing is working.
Thanks Guys
also, any advice would be awesome.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 1 of 9
(4,920 Views)
here is my array
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 2 of 9
(4,919 Views)
Have you simply tried making the false color transparent? The array frame can also be transparent.
Message 3 of 9
(4,906 Views)
I did try that but for whatever reason it would not work
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 9
(4,899 Views)
Well, "for whatever reason it would not work" is not much of an explanation. Since you obviously did not post what you tried and saying you want the spaces to not be there is a bit unclear, maybe you can post what you have done or an image of what you want it to be.
Message 5 of 9
(4,894 Views)
After  looking at it for a bit I no longer care wether the space in between the Array is there our not, but I did try to make the space tranparent but that didn't work it literaly made it the same color I think this is because my background is gray as well, so yeah that is the only thing I have tried.
Thank You,
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 9
(4,888 Views)
Yes, when you make something transparent, you will see the background.
Message 7 of 9
(4,879 Views)
Accepted by topic author Harold_Timmis
If you don't want the spaces, you would customize the control and make the frame smaller than the colored area. It could look as follows (took me 15 seconds):
Don't customize the array, customize the element. 😉
Message Edited by altenbach on 05-02-2009 12:14 PM
Message 8 of 9
(4,870 Views)
Thanks man it did take me 15 sec lol
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 9 of 9
(4,857 Views)
