customizing system buttons
I have to customize system buttons for my application. So i inserted small icon on the button using the Control Editor for the true and false state.
But when i use these buttons in my application, I can see the true icon, the false icon but all icons disappear when the mouse is up to the control.
How can i do to see the icons when the mouse is up to the control ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,778 Views)
hi
1. Edit Mode/Customize Mode > Customize Mode
2. Select "Picture Item" to be edited
3. Import Picture (You may copy the picture/icon image to clipboard first)
Upon completion of customization, switch nack to Edit Mode, save the *.ctl
regards,
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,775 Views)
A boolean control has two additional states other than T and F and those are the transition states which you can see when you hold down the button.
As Ian suggested, you need to select those states when customizing the control and replace their images as well.
___________________
Try to take over the world!
(3,767 Views)
Thank you!!
(3,751 Views)
