cut image part
I'm using labview 2011 development vision.
I would like to know how can i cut a part of a image, every times that I open a new  image?
I need to cut every time a part of a image, all in the same local.
Can you post a Vi for me, please.
Thank You.
Thank You.
(3,721 Views)
Please explain what you mean by "cut a part of an image."  Are you trying to extract a constant ROI from every image?  If that's all your trying to do, there's an example on ni.com: Extract a ROI Example.
Vision and Motion Enthusiast
Certified LabVIEW Associate Developer
(3,707 Views)
..I need to cut pieces ( portion) of an image.
Example. I use the "rectangle tool" and i draw a rectangle in the image for cut this piece and when i finish the draw in the image. The software remove all part of the image that was out of the rectangle.
I need to use the rectangle tool for cut some pieces of the image.
Thank You.
(3,682 Views)
i want to extract the nuber plate from the entire image(front nuber plate) . How can i do this?
(3,634 Views)
