cwGraph3D LV2010
I installed the Eval version of LV 2010 to test if 64 bit helps with a performance issue I was seeing.  Anyway, when I open a cwGraph3d plot from the Classic Graph palette I see a grey box with "Control could not be loaded"  Where did it go, and how do I retrieve it?  It still works in LV8.6 on this machine.
Tim Elsey
Certified LabVIEW Architect
(4,467 Views)
The 3d graph controls are built ontop of activeX controls that Microsoft did not port to the 64-bit version, so they were removed from the palette.
- Regards,
Beutlich
(4,448 Views)
Does this mean that installing a 32 bit version on a 64 bit machine will not help at all with cwGraph3D control?
(4,242 Views)
32 bit LabVIEW cwGraph3d should work fine in 64 bit OS
Tim Elsey
(4,238 Views)
Thanks Tim, I'll give it a go.
(4,233 Views)
