cwgraph surface
Hello everyone,
i have a problem with the CWGraph 3D from LabView 2009. I want to plot measuring points with different colors (according to their respective measured value). This works quite well.
But as soon as I change the style of the plot from points to surface or contour nothing will be plotted. What might be the reason for that?
Thanks in advance for your help.
(2,982 Views)
I believe yo uwill have to do a Parametric Plot to show the surface. WHen plotting a surface the 3D graph has to "know" which points are "adjacent" on the surface. The 1-D arrrays don't give that info.
In a Parametric plot the data is presented to the graph as a 2D array.
See this thread for a worse case example of using the CW 3D graph. Here is a preview.
Ben
(2,963 Views)
