cycle counter in a wave
Hi.
I wonder how I can do to put a cycle counter in a wave that is constantly simulating and which will change the frequency, amplitude, initial force and samples / sec.
Thanks.
Message 1 of 11
(4,274 Views)
The input parameters to this signal generator define how many cycles will be generated. Is that what you are looking for?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 11
(4,251 Views)
Hi Mike.
Yeah so I'm looking for but this wave will be continually changing parameters such as sample rate and this must be taken into account.
I want to know the cycles that do the wave while each wave has different parameters.
I explained well?
thanks
Message 3 of 11
(4,229 Views)
Each time the VI is called you calculate the number of cycles generated. Total those values and you get a total number of cycles.
Mike...
LabVIEW Champion
Message 4 of 11
(4,219 Views)
How do I calculate the number of cycles generated?
Message 5 of 11
(4,204 Views)
If you want to generate waves continually, you can add while or for loop.
And use parameter "i" inside the loop, and you can know what cycles in your program.
Patrick
Certified LabVIEW Developer
Message 6 of 11
(4,197 Views)
Hi Patrick
I think with the parameter "i" know I can program cycles but not the cycles of the waveform.
Thanks.
Message 7 of 11
(4,182 Views)
Because the counter restarts all the time?
Message 8 of 11
(4,134 Views)
Use another Shift Register on the outer loop to hold the count as well.  Right now, the count will be reset each time you run this check (shift register is being initialized to 0 each time the FOR loop is started).
Message 9 of 11
(4,121 Views)
Hello.
Can I have it I can explain graphically? I have little experience in labview.
Sorry.
Message 10 of 11
(4,110 Views)
