cyclic autocorrelation and spectral correlation density function (CA & SCDF)
Does someone implemented these two discrete analysis tools in LabVIEW (the cyclic autocorrelation function or/and the spectral correlation density function)?
I have tried but the results that I get are different with what is expected. I think I have a problem with the complex-numbers treatment but I am not sure. In attachment you can find my code. Just run the vi called Test_SCDF.vi
I hope you can help me with this problem.
Thank you in advance
PS: the fourth vi is in the next thread 😉
Message Edited by crimolvic on 03-22-2007 09:27 AM
(4,318 Views)
here the fourth vi
(4,315 Views)
I tried to implement those analysis too. But I just used labview few times, and i am not sure how to do. Are your problem solved? Would you like to share your solution with me?
Thank you.
(3,533 Views)
