daq assistant : saubvi is not executable
Hi
I want to measure three axis forces on milling by using labview software .  I do not know labview so my friend wrote a labview program for me bu ı couldnt operate it . It worked my friend's laptop but it didnt work on my pc. When I open the file it can not find some "vi" therefore I am sending the front and block diagram pictures for better understanding  My friend is far away and I really need your helping  I have labview 8,5   traditional daq  TDAQ744 loaded in my pc . My daq card is PCI  6036E  .  The other daq card on laptap is 6024. All daq cards are introduced to pc and work properly.  ı dont understand why it can not find the "vi"s .
(2,831 Views)
hi,
For DaQ assistant to work, you should have installed  DaQmx driver in to your PC.
If not then install DaQmx  and then try running.
thanks&regards
Senthil nathan
(2,824 Views)
