daq assistant vi for trial version
Hi guys. I didn't find daq assistant express vi in labview 2009 trial version. I want to use this after analogue device simulation in MAX for various analogue signals. Can anybody please send me vi template code for daq assistant.
Many thanks for your support.
(4,612 Views)
You need to download and install the DAQmx device drivers.  Once you have that, the DAQ Assistant will show up in the palettes.
(4,608 Views)
Hey Guys,
Ravens Fan is absolutely correct. When you install DAQmx, not only will it install drivers for all NI DAQ devices it will also install support for any NI application development enviroments you may have installed - including LabVIEW. (Note: it is therefore important to install DAQmx after you have installed LabVIEW).
The following link takes you to a location where you can download the latest version of DAQmx.
http://joule.ni.com/nidu/cds/view/p/id/1444/lang/en
Not that is a fairly large file, so you may want to download it over night.
Best wishes,
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(4,594 Views)
thanks guys.
I've experienced when Labview is pre-installed in machine, installing daqmx doesn't complete and error pops up saying earlier version of ni daqmx needs to be removed first which means uninstall labview 2009. At the time of writing I already had removed labview from my machine and installing ni daqmx 8.01 first.
Am i doing the right thing?
Ta
(4,578 Views)
" (Note: it is therefore important to install DAQmx after you have installed LabVIEW). "
Nor does uninstalling DAQmx require you to uninstall LabVIEW.
(4,574 Views)
