daq assistant
I wrote a test program in LabVIEW 8.5 and updated it in a later version. I have now updated my system to LabVIEW 2011 and went to update the test again and the test will not execute and says my DAQ Assistant vi's are not executable and when I try to click on the to see them I get a message stating unable to view properties. Anybody else run into this and how did you fix it.
(2,754 Views)
Hi chirs,
LabVIEW claims to be "unable to view the properties" when you didn't install DAQmx from the device driver DVD...
(2,742 Views)
