daq973A communication
I am trying to talk to a DAQ973A scanner in order to collect voltage data from 3 different channels.
i downloaded the driver and it does not seem to work. i get this error message when i run my labview code
i attached my code. please help
(919 Views)
Hi Johm,
Your device IS working with LabVIEW, you even get a response that tells you what exactly went wrong!
Read the (programming) manual of your device, it will explain the reasons for the errors mentioned inside the response dialog: the "-230"/"-420" are error codes generated by your DAQ97x device…
(885 Views)
