daqmx create channel (ai-voltage-basic).vi
what can i replace (daqmx create channel (ai-voltage-basic).vi) if i don't have the right equipment
(4,142 Views)
You could simulate the equipment that you need.  Then you don't have to change your code.
Does that help?
(4,138 Views)
Please use the actual text box to type your message rather than the "insert code" box.
What is "ai-voltage-basic.vi"?  It sounds like something from traditional DAQ.
Perhaps you should give a bit more description as to what you are trying to do.
(4,137 Views)
"daqmx create channel (ai-voltage-basic).vi"
That is the default polymorphic instance that is placed on the diagram if you go to...
Measurement IO >>> DAQmx >>> Create channel.
So in that context the idea of creating a virtual device in MAX is a good first guess.
Ben
(4,120 Views)
