daqmx for pocket pc emualtor
I am trying to develop a labview application for pocket pc. for this purpose i instal the pocket pc emualtor on my desk. i run the labview for pocket pc emualtor and eveloped a simple application it run ok. i want to acquire data from my NI card for this i instal DAQmx now when in my labview for pocket pc emualtor when i checked my function pallete in block diagram i did not find any daqmx vi pallete neither any other daq pallete .there is ? in the NI measurment .What should i do how can i acquire data for pocket pc emualtor using daqmx is there any other driver should i install.
(2,394 Views)
Hi, Have you had a look at the following link from the National Instruments website? It might be worth going through the following steps in the Knowledge Base document at the link as the first thing to try. If the problem is still there, post back and I will see if I can find some further information as to why this is happening. http://digital.ni.com/public.nsf/websearch/53149DDE0296918286256FCB005FCE6F?OpenDocument Hope this helps. Regards Lilly N National Instruments UK
(2,373 Views)
