data acquisition and put it in an array in regular sequence
Hello, NI experts
 I'd like to get some advices about how to put acquired data in an array in regular sequence in FPGA
In FPGA, the data is analog data from sensor.
1st data => allocate on index 1
2nd data => allocate on index 2
i th data => allocate on index i
Any advice is welcomed.
Thank you.
Hyo
(3,595 Views)
use insert into array
and use empty array to start
(3,569 Views)
Accepted by topic author catalysthw
You should read more carefully.  We are talking about FPGA here.  FPGA must deal with Fixed Sized Arrays.  So you have to initialize the array and then use Replace Array Subset or just use a FOR loop.
Of course, it really depends on what the OP is really trying to do here.  Perhaps a little more context would help us give you a better answer for your situation.
(3,538 Views)
Thank  you so much!
(3,509 Views)
