NI has a very broad range of tools that would fit this type of application. Identifying which tools will fit your needs will require a more indepth specification of system parameters. I highly recommend that you use the on-line DAQ Designer at http://www.ni.com/daq/ddonline.htm. If you prefer you can also enter a conversation on-line by following the "Ask an Expert" link at the bottom of any on-line catalog page.
