data acquisition using picoscope
Hello and good day
I'm actually doing research for my project.
my problem is that. can labview operate with picoscope 5442B?
if can. can someone teach me how to write the program since i'm new in this scope
thanks 😄
(7,124 Views)
Labview can communicate with many devices, the key is identifying what info you need to make the program.  Provided the manufacturer doesn't already provide VIs, you'll need to make your own.  For this you'll need the following information to start.
Does the picoscope use GPIB (what's the device address?)? RS232 (buad rate, terminating characters, stop bit, parity?)? USB ?
What commands would you need to send (usually short string messages)?  Check the user manual of the scope for this info.
(7,115 Views)
pjr1121. can i get your email for futher discussion?
(7,111 Views)
Haven't you tried the driver available from the vendor?
(7,097 Views)
is it named 'picoscope 6'?
(7,090 Views)
a quick look through the manufacturer's website shows that you want the Softwar Development Kit (SDK) located here.  http://www.picotech.com/software.html
It contains labview examples along with DLL wrappers (the subvi's you will be using to construct a functional program)
(7,087 Views)
