data acquisition vi crashes when it is building
This didn't happen initially, but after I started adding more things (renaming the channels, adding custom curve fits to it, etc) the Data Acquisition VI started to crash on me every time I tried to rebuild it. Does anyone have any experience with this?  Thanks.
I'm running Labview 8.0 and Windows XP.
(2,539 Views)
Hi jwbrooks0,
you can try to copy the entire code into a new subvi. Sometimes it helps.
Mike
(2,525 Views)
Hi JwBrooks
What functions did you add to the application that may have caused the crash? Were any of these a DAQmx function?
Thank You
Eric Reid
Motion R&D
(2,510 Views)
