data acqusition averaging
I am fairly new to labview and programing.
My goal is to acquire retinal potentials, The signal I obtain is accompanied with noise and is in micro volt range, my goal is to average out the noise so that I can analyze the actual (signal without noise) signal.
The incoming analog signal is continious, but I need  an alternating 25 second time window  to be averaged, which means: average signals from 0-25 sec. do not average from 26-50 seconds, average from 50-75 seconds and so on...
I managed to write a VI that doesnt show any errors, I was hoping if someone could guide me if I'm wrong. If so, then, Smiley Sad
 How do I go about averaging the data at 25 second multiples (for 25 seconds from the start point)???
Help will be awesome. Smiley Happy
Thank You
(3,288 Views)
Duplicate Post
Please don't start another thread with the same question.  You are already being helped in the original thread.
Or an earlier post.
Or the original post
(3,281 Views)
This discussion has been moved here. Sorry for the multiple posts.
(3,178 Views)
