data adquisition
Hello
how can I acquire data from the pc task manager in labview?
(5,007 Views)
Probably learn how to translate .NET code into LabVIEW.
(4,920 Views)
What information in particular are you looking for?
You can run a System Exec command with the command "cmd /c tasklist" to get a string containing the running processes.
(4,916 Views)
acquire the data and be able to save a history of the task manager
(4,901 Views)
In case you couldn't get what you want from the cmd tasklist or similar powershell Get-Process calls. If you are looking for something that tracks cpu usage you could take a look at this .net example and adjust it to fit your needs.
https://forums.ni.com/t5/Example-Program-Drafts/Monitoring-CPU-usage-on-Windows-from-LabVIEW/ta-p/35...
(4,885 Views)
