data aquisition on parallel port
I have connected the board and opened the exemple in labview! I RUN it! When I press START (manual start on the board) the number 17 pin turns off and then back on! so ...the exemple works...as the number 17 pin is indeed the MANUAL START PIN.
The sensors are ment to be read on the pins 1, 14 and 16!
You were talking about extractig the line...how do I do that?
Message 11 of 15
(933 Views)
Those are control lines from the pc. Why did you use those instead of the data lines? In any case, they are bits 0,1,2 of the control register and you would mask off all other pins. For example, if you AND the data with 0x02, you will get just the data for bit 1. If the ANDed data is equal to 0x02, then bit 1 is high.
Message 12 of 15
(924 Views)
snuk wrote:
[...] opened the exemple [...]
I think that with "the example", you are referring to Parallel Port Read and Write Loop.vi. If you look into the blockdiagram, you will see "port in" and "port out"; those are the functions to read/write data to the parallel port. Just as Dennis wrote, you have to mask all lines to retrieve the line(s) you are interested in....
Still, each line will only return 0 or 1 (LOW or HIGH).....
Norbert
Norbert
Expert: Geometry
Message 13 of 15
(916 Views)
Hm, ok, now i think what you are up to: Port In, Port Out do only address data lines of the parallel port. Pin 1, 14 and 16 are control lines and therefore do not show up in the data read.
Pin No (DB25)    Pin No (36 pin)    Signal name    Direction    Register - bit    Inverted
        1                          1                 nStrobe         In/Out         Control-0         Yes
        14                         14             Linefeed          In/Out         Control-1         Yes
        16                         31             nInitialize         In/Out         Control-2         No
There are no functions predefined in LV to access those lines. You can write your own part of software to do this. You can find some introduction to this here
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 14 of 15
(912 Views)
Woha, again, i was to fast..... reading first, writing then would be better.....
So if you increment the port address twice, you will be able to read the control lines using "Port In". Just have to mask then.....
hope this helps,
Norbert
Message Edited by Norbert B on 07-07-2009 09:26 AM
Norbert
Expert: Geometry
Message 15 of 15
(906 Views)
