data aquisition software help
I am an absolute beginner to Labview and began using the just last couple of months. I am primarily using it for data acquisition since I plan using Matlab for post processing.  So basically all I need for now is help in establishing code that will read 5 channels simultaneously as following: ·         2 pressure signal from NI 9215 module installed on cDAQ 9172 ·         1 temperature signal from NI 9211 module·         2 Digital signals from NI 9401 module generated by speed encoder. One signal is for speed and other is for triggering the data acquisition every 1 degre rotation.Sampling rate for all signals is the same of 50 KS/s  Thank you very much
(2,672 Views)
is it related to this thread?
(2,668 Views)
