data aquisition time
Hey guys,
I do not know if anyone can help me.
I am working with a PCI-6221 data acquisition board on a simple system which collects the voltage data from a capacitor. I just wanna take the voltage points during the capacitor´s discharge, which lasts 60ms aprox. I would like to take at least 10points, so it would be necessary to acquire every 6ms. I have tried it with a proucer-consumer format, but I face data overwritten troubles.
Can anyone tell me if it is possible to do this? As far as I know, the average time response of Windows is tipically of 10ms, so I think I cnnot do this without a real time module. Could you tell me which would be the minimum time interval between samples acquired?
Thanks in advance
(3,541 Views)
The most important thing when asking something about data acquisition is to tell what hardware you are using!
Christian
(3,537 Views)
Christian
Christian He has mentioned it as PCI-6221.
Jmhf,
  It would be better if you can post the code that you have done for this.
(3,533 Views)
@P Anand wrote:
Christian
Jmhf,
ups. Thank you Anand!
Well then simply create a finite Task with the number of samples and sample rate you want to acquire based on the example named "Acq&Graph voltage-Int Clk.vi" which could be found using the Example Finder.
Christian
(3,530 Views)
And can I reach as high rates as I told? I want to take one point every 6ms!!!, queue them and then process them.
(3,526 Views)
6ms means 167 Hz. The 6221 maximum rate is 250.000 Samples/s, so yes.
(3,520 Views)
