data base
hello ni,
                   i am doing project with database with sql server, in my first column i want insert the date time another some columns occupy string and next 30 columns contains array of data with SGL format at the last column occupied test name as a string.
my question is that i want to create a bundle of variant data programatically. currently i am using insert.vi from data base toolkit. please find attachment, this method i am doing.
is it possible to create the variant programatically...?
i already tried the query base to insert the data, but for that i have to indentify the data type. it will be very difficult task.
can you suggest me anything.
Balaji DP
(3,020 Views)
Hello Balaji,
What exactly do you mean by creating the variant data programmatically? And what's the issue with the current method? Please clarify.
Vaibhav
(2,947 Views)
