data base
Hi all : Issue is data base  Please attach see file , copy this file to desktop ,, then run create table  vi ,,, as you see its will save the data in access . Please see  I took the this example from national instrument example directory C:\Program Files\National Instruments\LabVIEW 8.5\examples\database  but I add some objects My problems are : 1-       Every one can insert to epos.mdb and do changes 2-       I want if I insert same number in  column 1 , massage appeared that say this number is in data base , and don't saved it , if this number doesn't exist then application will saved it   How can I do that?  thanks
(3,963 Views)
first you find the value in table colum 1
and you put a condition if norecord found   connect to a case T/F
and if tru save the record and if not  message box.....
(3,959 Views)
I know the concept ,, but how can i found the value , i need appliaction to run on all colunm 1 , how can i do that
(3,944 Views)
are you familiar with sql or database query and table etc...
where did you get the database exemple, they should refer to a reference
(3,935 Views)
if you have labview 8.5 installed , see C:\Program Files\National Instruments\LabVIEW 8.5\examples\database
(3,929 Views)
the exemple just cover the creation of a table, but not the insert record.
I do not have the database add on but I am using a database not connected yet to Labview.
To answer your question you should first use create table with the database app(like access: simpler)
                next find the function vi to (findRecord(like query)  and Numberof record  and insert record.
(3,911 Views)
