Hi there,
I created a small example for you (see the attached "StreadsheetToPower.vi"). This example creates a sine wave and a square wave and plots the two waves on a Graph. After that the data is saved to the "data.txt" file by using the high level spreadsheet file I/O VIs. We then read the file and extracts the FFT power spectrum from the timed data using the delta time "dt" from the front panel. "dt" is important, since this tells the "FFT Power Spectrum.vi" how the data is related to time.
I hope you find this information useful.
Philip C.
Best Regards,
Philip C.
- Philip Courtois, Thinkbot Solutions
