data format
Hi, my instrument need a string with three bytes to move. I can send this
through IBIC by the format \x100\x20\x0 and it will read back to me three
bytes sent. But when using Labview I just can't figure out a correct way
to send a string with three data bytes. When I sent the same format like
\x100\x20\x0 and it will count as 12 bytes.(use write and read to do this)
Anyone knows what is the correct data format and what is a seperator for
the data and how do labniew count bytes? Thank you here first.
(2,836 Views)
>bytes to move. I can send this through IBIC
>back to me three bytes sent. But when using
>way to send a string with three data bytes.
>(use write and read to do this) Anyone knows
>a seperator for the data and how do labniew
Right click the string control, and select
Hex Display. Then type "01002000". x100
is 2 bytes (x100= xFF + 1).
Good luck.
George Zou
http://gtoolbox.yeah.net
http://gtoolbox.topcool.net
(2,836 Views)
