data in first column of saved file is not continuous
Hello again,
It actually appears that if you use the formula node, and the first listed variable in your formula is the variable that will correspond with the actual signal coming from your acquire signal, the dt value should not be changed.  I would go ahead and switch the "R" variable in your equation to be the first variable listed (X1) in your formula node, and have the other constant values follow that in the formula.  Your actual equation does not need to change though.
Let me know if this fixes that issue.
-Travis
Travis M
LabVIEW R&D
Message 11 of 16
(797 Views)
Hi Travis-
Thanks again for all the help!  Could you re-send sherri.zip in Labview 7.0.  I can't open the previous .zip b/c it's 7.1.
Thanks again!
Sherri
Message 12 of 16
(791 Views)
Oops -- my apologies. Here is the VI that I think you will be most interested in.
Please let me know if it helps!
-Travis
Travis M
LabVIEW R&D
Message 13 of 16
(790 Views)
Hi Travis-
Thanks so much for your help.  My times are now continuous, but my mean temperature values are intermittent.  Do you have any thoughts?  Attached is my VI.
Thanks again for your help.  You've been very helpful!
sherri
Message 14 of 16
(771 Views)
Hi Travis-
You can ignore my previous message.  I figured out my problem!  Thanks again for all your help!
sherri
Message 15 of 16
(766 Views)
Glad I could help!
-Travis
Travis M
LabVIEW R&D
Message 16 of 16
(756 Views)
