data log file refnum - what is it?
Hello all,
i want know what is it data log file refnum and how to use it.
Thanks.
(3,971 Views)
A datalog file is a file that stores data as a sequence of records of a single, arbitrary data type that you specify when you create the file. Although all the records in a datalog file must be a single type, that type can be complex. For instance, you can specify that each record is a cluster that contains a string, a number, and an array.
You could use a datalog file refnum if, for instance, you were creating a subVI which will be accepting a datalog file as an input. You could use this refnum to write to the file and perform other actions on it.
J.R. Allen
(3,971 Views)
Thanks, JRA
(3,971 Views)
No problem. Good luck with the programming!
J.R. Allen
(3,971 Views)
