data logging every 0.5 voltage.
I'm new to Labview.  I am trying to create aVI that would log data into excel file every 0.5v voltage drop.  Fox example, in my VI code every time my BEAM voltage drops from 1.0v to 0.95v, 0.95v to 0.90v, 0.90v to 0.85v so on; i want my VI to log my BEAM reading and MIC reading. it doesn't matter what MIC value is at time of voltage drop.  Please help.  I've attached my rough VI.
(3,961 Views)
Hi Amit,
never, never ever, under no circumstences compare floating point numbers for equality!
Now you should define that "voltage drop" more detailed (maybe voltage drop in a certain time) as now you just compare current value with last reading...
(3,959 Views)
@GerdW wrote:
Hi Amit,
And if you do, first you give me another nickel in my retirement fund. Then go read this: http://www.parashift.com/c++-faq-lite/newbie.html#faq-29.17
(3,955 Views)
i am comparing current value vs last value.  I don't care about timing.
Thank you for your help
Amit
(3,954 Views)
Hello there,
my signal has too much noise or oscillations.  I want to take the a average every second or so and if the average value is less than 0.005 from the previous average value then i want to logg it.  Can anyone please give me an idea?  Thank you for your help.
Amit
(3,918 Views)
Hi Amit,
there are several functions in the Math palette to calc the mean - choose one of them...
(3,914 Views)
Hey Amit,
This example shows how to calculate a running average of an array which is similar to what you are looking to do:http://zone.ni.com/devzone/cda/epd/p/id/5229 You will need to modify this implementation in such a way that you can keep track of differences between the previous average and your average over the last second but the overall concept should be similar.  Please post back if you have any additional questions.
Kevin Fort
Principal Software Engineer
NI
(3,895 Views)
