data logs control
hai,
I'm using tektronix tds2000 series osciloscope for acquireing signal to labview and i've succeded in controlling the waveforms using the labview front panel.
Here i am not able to log the data during the run time. And also how to add the other user defined parameters like names and description which has to be above the readings that are acquired from signal.
As shown in the below attachment the headings are to be in the top and then the readings table.
So please suggest me a solution.
(3,008 Views)
Hi teja,
from your image I guess you want to create a table.
In LabVIEW a table is just a 2D array of strings. You need to create a 2D string array and replace the elements by the content you would like to display.
How to use basic array functions is explained well in the free LabVIEW online courses offered by NI on their website. Give them a try…
(2,981 Views)
