data loss in producer-consumer
I cannot view and store at the same time as it causes data loss. If I remove the cycle from the chart the data is correct without data loss, but I need to store and see the signal, I am using a notifier for displaying the signal.
Image 1 : no data loss, only save data
image 2 : data loss with chart
psd: i am using mpusbapi bulk usb.
(716 Views)
The "trick" of the Producer/Consumer pattern in LabVIEW is that loops can run "in parallel", and moving data around in memory is quite fast.  You have three loops:  Data Acquisition loop, which generates data at regular intervals, but spends very few cycles "inside the loop" because most of the work takes place in the hardware, a Plotting loop which gets an Array of data from the Acquisition loop (and needs to plot it at least as fast as the data are being generated), and a data-saving Loop, which writes data to disk (and is governed by disk speed, generally also pretty fast.
Data Acquisition -> Data Plotting is one Procedure/Consumer loop.  Data Plotting -> Data Saving is a second Producer/Consumer Loop.  When the Plotting Loop gets the data from its dequeue (acting as a Consumer), it immediately puts it on a Queue to the Data Saving loop, making it a (second) Producer.  Note that running the Producer or the Consumer takes very little time -- it's basically "copying data from one block of memory to another".  Because it is in a Queue, no data gets "lost" or "ignored" (unlike the case with a Notifier).  Note that Queues are "elastic" -- if one loop needs "a little more time" to consume, the data will "build up" in the Queue, and when the loops resume "full speed", they'll "drain" the Queue.
Bob Schor
(659 Views)
