data plugin for .mat files in LV2010
Hello, I am using LV2010 and recently downloaded the data plugin to allow Labview to handle .mat files. However when I try and use the plugins I get an error -2558, has anybody else encountered this? Is there a work around or a fix?
(2,451 Views)
Hi SSB01,
Can you please attach your VI and the mat file, so that we can have a look?
Mavis
(2,447 Views)
Here are the files, hope you van help.
(2,442 Views)
Hi SSB01,
   The MatLab DataPlugin only supports level 5 and level 4 MAT-file format.
   Your file is level 7.3 MAT-file format. So The DataPlugin doesn't support it.
   You can try save the file as level 5 format and read it again.
(2,424 Views)
